Hey guys I haven't been on here in awhile, but I getting my quaterpanel and door finally fixed Feb 16th. I'm trying to figure out what quarter mile time I can expect when I go to Rock Falls this summer.
Mods:
AEM Cold Air Intake
Ported Tsudo 4-2-1 Headers
Yonaka Cat Back Exhaust
Ported Throttle Body
Screamin' Demon Coil Pack and Wires
Bosch Plat+4 Spark PLugs
Kent Stage 4 Cams
Fidanza Adjustable Cams Gears
Massive Speed Underdrive Pulley
Then coming June first is:
Clutchmaster Stage 4 Clutch
Fidansa 8.5 Flywheel
Quaife Limited Slip Differential
Right now I think I'm running 130SAE Horsepower but it is also an automatic. Once it gets swapped and I get the clutch and stuff I should get way more through to the flywheel/wheel. Let me know what you guys htink. Thanks a lot!
Estimated 1/4 Times??
saintg2005
NEXT BIG PROJECT:
NEXT BIG PROJECT:
saintg2005
I'm talking about after I swap it to a manual and put in the clutch, flywheel, and limited slip
NEXT BIG PROJECT:
NEXT BIG PROJECT:
trahma
- has a blownup bomb
- Car: 2002 Malibu Blue ZX3
oh.. my mistake.
i'd expect low to mid 15's running that setup. Although you should look into FI if you want a car that can fast. It's near impossible to make decent power NA on a Focus. Ask Pitch Black or Elite Korri, they've both gone that route.
reconstruction.
saintg2005
Whats FI? Fuel injectors?Yea I know what You mean about the power I've heard that before but I have major things in store for my focus. I'm having a motor built (crower stroker kit, ported head etc) for a 8.5 compression and then boost factory is hooking me up cause they need a focus front man for the twin cities. So I'm definately going the power adder route but I wanted to find out what my times would be after the trans swap[/b]
NEXT BIG PROJECT:
NEXT BIG PROJECT:
Ditch that garbage.
Run OEM plugs and OEM ignition. The crappin' deamons is junk and bosch plugs suck the big balls.
I would guess mid-high 15's on the 1/4 with a stick.
Ditch that garbage.
saintg2005
You really dont think they help huh? I mean what do I know about that crap but I thought it would atleast help somewhat. Only 15's? i thought I would hit high 14's. Oh I forgot to write that I have a SCT chip too and run 93 octane because of my cam timing. I wanted it agressive but not too aggressive like for race fuel. If this changes anything let me know. Which is better cold air intake or a short ram with and hood w/scoop cause I get a cabron SS hood in June during the swap.
NEXT BIG PROJECT:
NEXT BIG PROJECT:
saintg2005
NEXT BIG PROJECT:
NEXT BIG PROJECT:
To get the rear covers out, you need to first remove the cover by where your front belts come out. Then in the back part of the rear panel there are two "plugs" that hold it in. Pull this out (it is virtually impossible to save them, don't worry though as they are worth like $.10 each). Then just wiggle it on out. There are some clips in the back holding it into the shell, and as you wiggle they will pop out. Kinda hard to explain, I had to pull em once before, get a hanes, it's all in there.
Nils
BTW: You aren't gonna shave a whole second from a gutted hatch...
Nils
Pappy wrote: To get the rear covers out, you need to first remove the cover by where your front belts come out. Then in the back part of the rear panel there are two "plugs" that hold it in. Pull this out (it is virtually impossible to save them, don't worry though as they are worth like $.10 each). Then just wiggle it on out. There are some clips in the back holding it into the shell, and as you wiggle they will pop out. Kinda hard to explain, I had to pull em once before, get a hanes, it's all in there.
Nils
gut the ac and power steering, bumper shocks, and, run a 100 shot of nos with that car.
*cough* yeah */cough*... I put any and every bolt on possible for my car:
I have a MTX
4-2-1 header ($200)
2.25" flex ($129)
2.25" exhaust ($200)
UDP ($129)
FR Stage II cams ($150)
Cam Gears ($350)
SD Coil + Wires (not really worth it, put stock back on) ($129)
FC Air Intake ($150)
EGR Delete ($10)
FS SCT Tuned Chip (mail order 93 oct) ($250)
AEM Sticker (haha, jk)
65MM Throttle Body ($200)
Total: $1897
sounds faster than stock, is faster than stock but probably only took probably 1 sec off 1/4 mile... ended up having ~140whp tops
Look at MCNEW n/a buildup, he is running 14 sec with a extremely lightened car, and 13 sec with a decent shot of n2o, he has a worked FR head and probably putting down 160whp
For all the money I spent, I'm ending up spending $2500 on a turbo including tuning and I'll be pushing 200-220 whp
go the boost! =)
I have a MTX
4-2-1 header ($200)
2.25" flex ($129)
UDP ($129)
Cam Gears ($350)
EGR Delete ($10)
Total: $1897
go the boost! =)
saintg2005
I am Greddy T3 and the whole nine yards. c the other post below or above. I'm just so friggin sick of puttin this money in and barely seeing anything out. EERRRGGGG!!!! I'm just gonna go turbo and that will be the end of it. You coming to the Feb 18 meet? Where is it and what time?
NEXT BIG PROJECT:
NEXT BIG PROJECT:
