is the 65mm tb worth it? cuz soon i'm gonna put in header, udp and maybe cam gears.
*oh yea its suppose to be udp*
65mm tb
yuepheng5865
- Car: 2000 Red ZX3
2000 zx3
65mm tb is good if you want extremely fast reving engine, more air flow, sensitive gas pedal... probably won't see much hp difference unless you have tons of mods, but it makes the car much more fun to drive
you wont get any HP, but its alot more fun to drive. i would say go for it.
the only reason MPG went down is because you cannot press on the pedal similar to the stock TB. Its more sensitive. Just take the time to learn how to drive and you'll be fine.
