I need help installing coilovers
DO NOT try to unbolt any of the rear control arms unless you want to buy new arms.
What part of town are you in? It's a pretty darn simple suspension to swap out.
FORDSVTPARTS wrote:DO NOT try to unbolt any of the rear control arms unless you want to buy new arms.
Some people dont have your expertice.
Depends, I'd say soak them repeatedly with PB blaster and if you have a propane torch you can heat up the nuts before trying to remove the bolts.bflesher wrote:Fronts are cake, the rears you will most likely have to cut the shock bolts.
Don't start your car on fire doing this though.
The rear shock bolts on mine have never been a problem but then mine have been through something like four suspension swaps so they aren't frozen in place.
You're breaking them loose before the rust ever sets inFORDSVTPARTS wrote:The rear shock bolts on mine have never been a problem but then mine have been through something like four suspension swaps so they aren't frozen in place.
Well yeah, isn't that the way you're supposed to do it?Redlineracer12 wrote:You're breaking them loose before the rust ever sets inFORDSVTPARTS wrote:The rear shock bolts on mine have never been a problem but then mine have been through something like four suspension swaps so they aren't frozen in place.
Thanks for the responses guys. I'm located in west mankato if you would like to swing by and help possibly. If you do just pm me your number. So I installed one of the fronts tonight and I can't figure out how the Hell that little bar connects to the coilover. The coilover hole is about 1.5" taller than that little bar..
By "taller" do you mean it's too high up on the strut to get the end link through?
Take pictures of the issue and post them.
Didn't work, try uploading your photo to Photobucket or similar... even Facebook would work if you copy the link.EvoFocus wrote:Here's the problem.
[img]coilover[/img]
Hopefully this works
Here you go. http://m1070.photobucket.com/albumview/ ... 0&newest=1
I made sure it was all the way in the knuckle this morning but this still won't go!
