4 bolt to 5 bolt?
There is a conversion kit I believe or somebody had made some.. Mybe somebody else could chip in here.
What exactly are you trying to accomplish? There are wheel adapters for this sort of thing, but generally they will mess up your offset. Especially if you're trying to use wheels that came off a Ranger/Jeep/Other RWD vehicle as the backspacing/offset is way different for them.
Doc
- Car: to many to list
No, I'm not trying to put ranger wheels on a focus or anything wierd like that. For now the project is top secret. Something I'm working on in my head and gathering parts for in the hope I can get the time to actually build it. I don't want wheel spacers, that would make the project even wider. I'd like to just swap out the hubs and rotors.
Ask arounf Focaljet, I know someone was selling five lug hubs but I can't recall who it was either.
an awd focus is alot of work. and swaping over to m3 bearins and brakes is the most cost effective route if a big brake kit is what your lookin at . junkyard parts
I know one guy made himself a set of five bolt hubs using stock hubs.
He welded a plug into one of the wheel stud holes and then redrilled the hub for the size he wanted, he couldn't get the pattern to work without plugging and welding the one hole because the spacing always hit the edge of one of the holes.
mazda 3. i am not 100 percent sure but i think early m3 s used a pinch style hub. swaping this part in allows a better brake package and if image is more important then you have more options for big dumb shiny rims.Doc wrote:awd focus??? That does sound like a lot of work.
I'm not after bigger brakes, just 4.5 - 5 bolt. Is that what an m3 has?
hermitmaster
- Car: 2012 Infiniti G37x
