Hi, I'm new to the forum, and looking for a used Focus to buy.
Can anyone recommend an independent Ford mechanic to do a prepurchase inspection of a Focus. It'll be a 2000-2007 model, most likely 2005.
I'm looking for a ZX5 manual without the timebomb engine, and they're pretty hard to find. So, I think I'm reserved to the sedan now.
Thanks
Prepurchase Inspection Mechanic Recommendation
The ZX3 and ZX5 were only offered in the U.S. with the Zetec and Duratec which are both virtually bulletproof.
The engine to stay away from came in the sedan, the SPI single cam, it is a grenade.
SPI was a 1.9 L right?FORDSVTPARTS wrote:The ZX3 and ZX5 were only offered in the U.S. with the Zetec and Duratec which are both virtually bulletproof.
No it was still a 2.0L in the Focus, actually might have been more cubic inches then the Zetec... The tell tale sign is the SOHC instead of DOHC though. Well that and the natural knocking sound the SPI makes lolPatalrob wrote:SPI was a 1.9 L right?FORDSVTPARTS wrote:The ZX3 and ZX5 were only offered in the U.S. with the Zetec and Duratec which are both virtually bulletproof.
I think back in the Escort days there might have been a 1.9L SPI...
The SPI also had a big valve cover. Zetec has a marking on the top of the valve cover "Zetec" and the Duratec is the 05 plus years.
That and the telltale chunks of valve seat flying out the tail pipe.Redlineracer12 wrote:
No it was still a 2.0L in the Focus, actually might have been more cubic inches then the Zetec... The tell tale sign is the SOHC instead of DOHC though. Well that and the natural knocking sound the SPI makes lol.
What part of town are you in?Skazi wrote:OK, so avoid the SOHC, right
Any recommendation on a mechanic around the Twin Cities to do a prepurchase inspection?
I'm in Aitkin, MN 2.5 hrs strait north of minneapolis. Doubt you'll be buying a car this far north though.
To be honest they're pretty basic, if it's clean and well maintained it's probably fine.
If it's a Zetec or SVT (especially SVT) see if the timing belt has beeen done, if it's an automatic does it shift properly?
If it's a ratty, beat up rattletrap then it's going to need a lot of help.
- Car: 2012 Infiniti G37x
It's not just miles, it's years as well.
I wouldn't go past eight years or 90k miles on an SVT.
The Zetec being non-interference isn't such a big deal since 99% of the time a timing belt failure isn't catastrophic, Ford suggests 120k on the Zetec.
