I know Its the knock sensor 1 circut...
But what does that mean??
P0325
- screaming4snow
- Car: 03 Screaming Yellow SVT
Kev
2003 Screaming Yellow
#3921 of 3985
#3921 of 3985
Looks like it's either detecting knock or it's a bad sensor or bad PCM. What are you running for fuel and what tune is in the car?screaming4snow wrote:I know Its the knock sensor 1 circut...
P0325 - Knock Sensor 1 Circuit Malfunction (Bank 1) See DTC P0326
P0326 - Knock Sensor 1 Circuit Range/ Performance (Bank 1) The knock sensor detects vibrations upon increase and decrease in engine rpm. The knock sensor generates a voltage based on this vibration. Should this voltage go outside a calibrated level a DTC will set. Knock sensor circuit short to GND
Knock sensor circuit short to PWR
Knock sensor circuit open
Damaged knock sensor
Damaged PCM
A knock sensor voltage greater than 0.5V with the key ON and engine OFF indicates a hard fault.
- screaming4snow
its an 03 svt, premium gas onlyFORDSVTPARTS wrote:Looks like it's either detecting knock or it's a bad sensor or bad PCM. What are you running for fuel and what tune is in the car?
its the stock tune that was "re-tuned" by ford years before i bought it.
Kev
#3921 of 3985
#3921 of 3985
