My point is this, I've been thinking, my stock clutch went out (58k miles, which isn't unheard of unfortunately) only a couple months after I replaced my master cylinder. So this got me thinking! What if the master cylinder had something wrong and caused the first failure and is causing this to not grab. I REALLY don't want to drop the trans again, what a PITA, so I'm trying to brainstorm what could be causing this! Also, I saw some dark fluid around the seam between the block and trans. Looked like a bit of engine oil, but it was impossible to tell where it came from because the whole under body was filthy.
I guess I'm looking for insight and wisdom, so let me hear your thoughts!
