Normal shop charge to put in a limited slip?
FocusMech.73155
warranty time is around 8 hours to remove, teardown and replace differential. non-warranty add about 1.5 to 2 hours and multiply that times shop rate. shop rate at my dealership is 129.95.......so you woud probably be looking between 1000 and 1200 to install it.
The time to do the diff would have been when the trans was out, then it would only have been a couple hours labor.
You could take out the tranny and take it in to a tranny shop to have them do the differential swap.
Look up Vince Lutz (Lutz Automotive) up in Hugo. I'm not sure if he's comfortable doing an LSD install, but his labor rates are extremely reasonable. When I did my clutch, I think it was $450 in labor.Miller wrote:I have no problem putting an LSD in, it's getting the trans out that sucks....
Just plan on waiting a while, he's usually booked for a couple weeks out.
- CrazySVTChick
- Car: 2003 Ford Focus SVT EAP
The LSD is the easy part of the job. That takes about 20min to crack open tranny take out old diff and drop LSD in and close her back up. It is the time to take the tranny out and put back in that is so time consumiong and frusterating.Patalrob wrote:You could take out the tranny and take it in to a tranny shop to have them do the differential swap.
I did my LSD in a day....even if the tranny caused me issues.
TURBO BABY!!!
