turn signal problems
Check the wiring going from the hatch into the body, there's been some issue with the wiring there getting brittle and cracking which causes shorts.
Any other electrical issues?
- screaming4snow
- Car: 03 Screaming Yellow SVT
my dome light stays on when its set to turn on and off with the doors opening and closing. after the doors close it dims and everything but doesn't turn completely off
Kev
2003 Screaming Yellow
#3921 of 3985
#3921 of 3985
Without looking at it, I can't tell for sure, but it sounds like a grounding issue. It may be a broken ground wire in the htch loom. It sounds like somthing that recieves power at all times lost its ground and is finding ground through your lighting circuit
