Hey,
Does anyone know if the spark plugs are hard to get to on duratecs?
I might pick one up, but wanna check the cylinder pressure first.
thanks
pressure test duratec
WASaZX3pos
Well it is in a car.... lol
But i found out that the plugs are under those plastic covers around the intake so it is possible....correct?
Duratecs use a COP (coil on plug) setup, so don't bother looking for spark plug wires.
Plugs are in the valley between the cams through the valve cover (very similar to the Zetecs). Carefully pull the coils, you should see plugs.
WASaZX3pos
If I'm not mistakin, Those are plug wires over the passenger motor mount, right?
http://www.ukcar.com/road_tests/Ford/mo ... engine.jpg
- Resident parts whore
- Car: 2000 autumn orange zx3
He is talking about the 4 cylinder ones.tgnorman wrote:Duratecs use a COP (coil on plug) setup, so don't bother looking for spark plug wires.
WASaZX3pos
I thought so. But v6s are wired. and easily checked right?
WASaZX3pos
Nah man, a swap like tht would be way too much for me I think.
But this car that has it in it seems a little weak.
