I have a 2004 SVT and the clutch is starting to slip so I need a new one. This is my daily and its bone stock. Any recommendations? I will be adding bolt ons with cams being the most aggressive addition, keeping it N/A.
Thanks for the input
New clutch
- ThatOneBigKid
- Car: 2002 Acura RSX Type-SC
2002 RSX Type-S - JRSC - Pulley Boys 3.2" Pulley (9 psi) - RC 750cc Injectors - Hondata Kpro ECU - GReddy Evo TT Exhaust - DC Sports Race Header - Injen CAI - Competition Clutch Stage 4 - Quaife LSD - 280whp
As long as you're N/A I doubt you'll need anything more than a stock clutch.
CFM has some stuff as does CLUTCHCITYONLINE.
- ThatOneBigKid
Can I just go with the Luk kit without the flywheel (around $250) or do I need the new style flywheel(closer to $525 for everything)?
Thanks for the input guys
- closetfordfan
- Car: 1996 ram
Get a new flywheel, also the luk clutch kit can be found on ebay for 400 dollars. Price is now 425
http://cgi.ebay.com/ebaymotors/LUK-02-0 ... 41512cfb05
- closetfordfan
- Car: 1996 ram
Ask and you shall recieve.
http://focus.c-f-m.com/freeshippingcatc ... st170.aspx
Oh $12... Well........... UR FUCKED
looks like a lot of fing around for just moving the power band around a little. still when getting the bigger cams(the only one worth the p.i.t.a) your still looking at 12 hundred bucks.closetfordfan wrote:Ask and you shall recieve.![]()
wink wink.....bitches- closetfordfan
- Car: 1996 ram
Of which cams do you speak?
- ThatOneBigKid
Picked up the Luk kit off ebay. 425 shipped to the house
Going to install the weekend of the 14th. Any tips or tricks to dropping the tranny?
@ FORDSVTPARTS - Do you have Flywheel bolts in stock for the 6 speed? (not sure if they are different from the 5 speed) I have heard that they should be replaced when the clutch is replaced. Do you recomend this.
$2.75 each and we do stock them, If you don't replace them be sure to use Loc-tite on the old bolts when you install them.ThatOneBigKid wrote:Picked up the Luk kit off ebay. 425 shipped to the houseGoing to install the weekend of the 14th. Any tips or tricks to dropping the tranny?
They are unique to the SVT.
- closetfordfan
- Car: 1996 ram
Rent an engine hoist to lift the trans in and out, it makes life a hell of a lot easier. You will need to rotate the trans counter clockwise to get it past the subframe (k-member). I also found this thread on focal jet to be helpful.ThatOneBigKid wrote:Picked up the Luk kit off ebay. 425 shipped to the houseGoing to install the weekend of the 14th. Any tips or tricks to dropping the tranny?
http://forums.focaljet.com/shift/603840 ... nters.html
- ThatOneBigKid
So after about 20 man hours I finally got the clutch replaced and i couldn't be happier! Feels like a new car!
