My zx3 race car has BAD over steer (i think thats what its called) it pushes bad in the corners.
What can i do or play around with to help fix this? I still have BOTH stock sway bars and ALL stock springs and shocks. I have been told to remove the front sway bar.
Remember this is stricktly a race car that only turns LEFT.
HELP BAD OVERSTEER
You want to stiffen the rear sway bar or replace with a stiffer bar. Losing the front bar might help, but it could cause more issues.
Whats the limit you can do with the suspension?
- closetfordfan
- Car: 1996 ram
Some ideas: svt suspension, alignment, staggered tires, short wheelbase on left side/ lengthen of right side, and that is all I can think of right now.
When the front end pushes that's understeer.
When the back end wants to come around on you that's oversteer.
- Car: 2001 ZX3 HORNET
Ok i have understeer then.
I have to run all 4 tires the same size.
- closetfordfan
- Car: 1996 ram
Use different tire pressures.ZX3_HORNET_RACER wrote:Ok i have understeer then.
I HAVE BEEN PLAYING WITH THE PRESSURE, I THINK IM GOING TO REMOVE THE FRONT SWAY BAR AND CUT ONE COIL OUT OF THE LEFT FRONT.
- Car: Pitch Black 2007 ZX3 S
Here's another idea. I was looking through some of the race pictures, and I see in the corner it looks like you just crank the wheel and mash the throttle. Try feathering the throttle and steering lighter.
Can u play with different spring rates? It's easy to setup a car for oval, just depends what your limits for mods are in the class
- Car: 2012 Infiniti G37x
thanks for the input guys, i know i need to practice, i dont have any experience.
- closetfordfan
- Car: 1996 ram
ZX3_HORNET_RACER wrote:I HAVE BEEN PLAYING WITH THE PRESSURE, I THINK IM GOING TO REMOVE THE FRONT SWAY BAR AND CUT ONE COIL OUT OF THE LEFT FRONT.
RELAX! I'M JUST TRYING TO HELP!!!
