How much pressure is this guy under?
Can I just cut the hard line, splice in what I need with soft line, double clamp it and it'll hold W/O leaking?
What I'm thinking is run the pressure line off the bottom of the pump up to the bumper support, through the inner fender and out the hole under the fuse box. Same for the return and one of those heater hose lines. Should clean up the bay a bit is my hope.
Just sitting here trying to figure out how to do it cheap, heater hose is easy, probably move that tree thing too. But the P/S line I'm not sure on. I know I can have a line made or I could just do hard line the whole way and leave some soft spots for flex (which is what I'd like to do, I figure some bulk 3/8" steel line should work).
Figure it's about time I do this.
re-route power steering line?
- Cajun Mafia
- Car: 01 Street Wagon/02 ZTW
Don't know. Good project though.
I wonder if AN line would hold enough pressure? Spendy, but it looks cool.
I'm sure it would apart from where it attaches to the rack. That looks to be a flange deal of some sort. Pressure and return are on one plate that bolts to the rack. More 'stupid Ford' far as I'm concerned.
If it's a flange that bolts to the rack, I imagine you could either machine a new one with threads on it, or tig weld a fitting onto it.iminhell wrote:I'm sure it would apart from where it attaches to the rack. That looks to be a flange deal of some sort. Pressure and return are on one plate that bolts to the rack. More 'stupid Ford' far as I'm concerned.
Now you've got me thinking.....hasn't really been a cleanly tucked focus engine bay, I might have to drink beer and stare at it for a while, get some ideas for routing...
Screw staring at yours. Here's mine for you to enjoy
This is the flange,
Here's the hole I'ma try and shove everything through,
You figure you get rid of 3 lines you're left with 1 heater hose line and the wiring. If I where smart I'd just tuck all the wiring away and use something to fool the ECU (I don't use either of those O2's or the fan wiring, or the EGR, or the cruise, or the A/C, christ I could get rid of a lot of shit, LOL).
It's a damn never ending battle I tell ya.
This is the flange,
I'm pretty sure a double clamped hose isn't going to work, it might hold for a while but I can almost gaurantee it'll pick the absolute most inopportune time to pop off and leave you stranded or with an oil fire under your hood.
I got the wiring moved. I had to add 8" to a few of the wires, should have added a bit more (about 16" would be perfect and give some slack).
I can't find any place to hide this stupid hood release cable though. I can't remember where it was routed stock, swore it was in the inner fender (I'm on my 3rd cable, all replaced by Ford). So it stays on the engine side of the inner fender.
Boy are you wrong ... soooooooo wrong.
At idle the pressure side is around 300psi. Turning the wheel it'll spike up to 600psi. The system has a max rated pressure of 800psi. Believe that's what I'd read at least.
Anyways, you're late to the party. Didn't pan out, line blew off. Said screw it and bypassed the pump and left the pump run dry. Well that tore up the bearing pretty good (no shit). And now I'm broke down. My own stupid fault for being a cheap ass, but I wouldn't have it any other way
Gonna have a buddy do some welding for me and make a dummy pulley.
er did you talk to someone who told you all this already? (which would be really weird as only a few people know it)
- has a blownup bomb
- Car: 2002 Malibu Blue ZX3
The power steering line has been the bane of my system for quite a while. Always had leaks in it and never really solved them. I think I did now but we'll see. Realistically I wish I could just find a local shop and pay them to do it so I can bring it back to them when it breaks again. It's annoying as shit.
reconstruction.
ha sorry fogot the fist nuber one as in elven hundred but still wrong. youd think two fuel injector clamps wooda held.hmmmmmm wounder if the hose was rated right? possible kink or collapse and over pressure.iminhell wrote:Boy are you wrong ... soooooooo wrong.
Anyways, you're late to the party. Didn't pan out, line blew off. Said screw it and bypassed the pump and left the pump run dry. Well that tore up the bearing pretty good (no shit). And now I'm broke down. My own stupid fault for being a cheap ass, but I wouldn't have it any other way.
