Zex Wet Shot Nitrous Kit
Has anybody installed a wet nitrous kit into their zetec focus? Where did you connect the fuel line?
You need a mcnews or other brand fuel rail adapter. It replaces the end cap on the right side of the fuel rail. Hope your engine doesn't eat itself like mine did when I ran that stuff.
I plan on running a 50 shot, what shot did you use?
Are you going to be at the meet on the 24th.
so you did 65 on a svt? Was there anything wrong with your set up I should know about?
ouch, now im nervous. Was it tuned?
Should've used more duct tape....focinite wrote:yeah, but from what i remember it melted the ground straps off plug alot and, had an issue with keeping the motor bits in the motor.
- Car: 2003 Black SVT focus
well his problem was it was a zetec...id run a 50 shot on a SVT motor without worrying about it
I was planning to do a 50 shot on a zetec untuned, not a svt.
I ran a 75 shot a ton of times un-tuned with 100 octane. If i were running n20 again I would get this: http://www.jandssafeguard.com/
From what I understand Pappys was an untuned dry kit.
nuff said.
nuff said.
