Front Calipers
HilloNative
Car: 2004 Sonic Blue SVTF
Well, i got new front calipers(there not going in yet) , since this will be an upgrade to my car i want them in the best condition, and since i got them used i was just wondering a good place to have them check out or get some maintenance?
You can get a rebuild/hardware kit for pretty cheap. Ask Steve!
Stock calipers?
HilloNative
no, i got these...
tgnorman
Car: 2008 VW GLI
Hope you got bigger wheels....I'm fairly sure brembos don't fit under EAPs...
gone, but not forgotten
HilloNative
no, not yet, im slowly getting parts for the car and i think i will start putting them till next year. But now that you comment... wasnt the RS wheels 17 "???
HilloNative wrote:no, not yet, im slowly getting parts for the car and i think i will start putting them till next year. But now that you comment... wasnt the RS wheels 17 "???
No 18x8"
I believe they'll fit inside a 17" wheel but the issue is going to be spoke clearance.
tgnorman
Car: 2008 VW GLI
FORDSVTPARTS wrote:I believe they'll fit inside a 17" wheel but the issue is going to be spoke clearance.
Parts god has spoken.
That is what I meant, but the midget keyboard on the phone isn't the easiest for long-winded posts.
I wouldn't take it as gospel though, I'm not positive about them fitting inside 17's.
dartfork
The Brembos on my car are similar. None of the SVT wheels worked unless you put an inch of spacers on. You need a 40+ offset and even then the styling of the spokes can get in the way.
HilloNative
^^^ thanks very handy info, i guess i already set my mind on getting new wheels, but is there anywhere where i can have them check ?
dartfork
HilloNative wrote:^^^ thanks very handy info, i guess i already set my mind on getting new wheels, but is there anywhere where i can have them check ?
How do your new calipers bolt on? With the Saleen/Brembos they use an SVT knuckle and then there is an adapter that bolts in between the caliper and the knuckle to push the calipers out further for the larger diameter rotor. If these use the same diameter rotor as the SVT and therefore just bolt on to your SVT knuckle. You could just mock-it-up and try out a wheel before you commit to the wheels. (thats what I did) If you know the disk/rotors these calipers use are bigger, it looks like you need the correct adapter before you can try it out.
Or you could just "eyeball it". A 17" wheel with a positive 40 mm offset that is styled "flat" or even has some forward curve will probably work. As long as that curve doesn't connect at the rim further back (less offset at connection point).
See how this example's "positive offset" wheel curves back by the rim. This will be interference with the caliper. So avoid that kind of styling.
src="http://kmhafer.datsun510.com/wheel_offset.jpeg" alt="Image" /></span>
HilloNative
^^^ they bolt right in... hehehe, is funny because now that you mention, some people from other forums are telling me that they might fit my wheels, or at least a 17 x7.5. Im going to try them this weekend to see if they fit the wheels.
Thanks.
i have a set of 71x7.5 with a 41 mill of set that may work for a test fit. now i got a garge to work in . 8)
