![Confused :?](./images/smilies/icon/confused.gif)
Axle install problem
- ch435
- Boom. Oh shit...
- Car: 02 Subaru Outback
Does anyone have any tips on getting the drivers side axle installed? That c-clip is making it difficult. We tried tapping it in, but how hard to you have to tap? We just can't get it to go in all the way. ![Confused :?](./images/smilies/icon/confused.gif)
Let's go boating.
![Image](http://i210.photobucket.com/albums/bb144/ch435/sigpic6111_2.gif)
Just pull it and spin it and try re-installing again.
I personally don't tap them in, I often times 'beat' them in with a mallet.
Yeah, it shouldn't be that difficult to get them tapped in. twist and push. everything has got to line up before it will go anywhere.
Is that the same one that was pulled out of its own CV joint?
I haven't had any problem putting my CV's in my car they seem to slip right in with a little push to get them past the C-Clip
Getrag vs MTXPatalrob wrote:Is that the same one that was pulled out of its own CV joint?
![Cool 8)](./images/smilies/icon_cool.gif)
![Image](http://i5.photobucket.com/albums/y171/FORDSVTPARTS/Main/Forum_Banner_10-1-2013_250x50_zpse493beb2.jpg)
I'm gues Getrag's are a little easier'r'r to work on?FORDSVTPARTS wrote:Getrag vs MTXPatalrob wrote:Is that the same one that was pulled out of its own CV joint?
![Very Happy :D](./images/smilies/icon/biggrin.gif)
no, the short shaft likes to stay where it is, and a special fork is needed to drive it out from the pass side of the trans.Patalrob wrote:I'm gues Getrag's are a little easier'r'r to work on?FORDSVTPARTS wrote:Getrag vs MTXPatalrob wrote:Is that the same one that was pulled out of its own CV joint?
![Sad :(](./images/smilies/icon/sad.gif)
![Image](http://i186.photobucket.com/albums/x121/focinite/robscarrim026-1.jpg)
This is on the MTX right?focinite wrote:no, the short shaft likes to stay where it is, and a special fork is needed to drive it out from the pass side of the trans.
on both, but if your trixy you can pop it out wiff da richard pryerPatalrob wrote:This is on the MTX right?focinite wrote:no, the short shaft likes to stay where it is, and a special fork is needed to drive it out from the pass side of the trans.
I didn't have any problems getting mine off.focinite wrote:on both, but if your trixy you can pop it out wiff da richard pryerPatalrob wrote:This is on the MTX right?focinite wrote:no, the short shaft likes to stay where it is, and a special fork is needed to drive it out from the pass side of the trans.
A little pressure with a pry bar and pop it came off.
