The wife is at MOA and says her steering wheel is stuck. Says she can put the key in and start the car, but the wheel is locked.
2004 2.3 5 speed
Any ideas?
Help!
My lock is getting pretty iffy these days too. I was stranded at Micro Center for about 20min and again at a friend's house for another 45min last weekend. About the time I was going to take it in and have it looked at it suddenly stopped acting up.
My girlfriend's '03 has had several lockups too but again not often enough that we're going to do anything about it just yet.
Sucks though either way glad to hear you got it all worked out.
FocusMech.73155
Thats because Ford's replacement ignition cylinder does not fix the problem. After a couple of years they start doing the same thing again. The next time it happens stick the key in the ignition and tap the end of it lightly with a hammer while trying to turn the key. It doesn't always work but some times it might get you away from being stranded.frankjt96 wrote:It's a very common problem, Ford knows about it, but refuses to make a recall on it.
Yep, works like a charm. If it's not too bad, you can usually just jam the key in with some force and it'll loosen up.FocusMech.73155 wrote:Thats because Ford's replacement ignition cylinder does not fix the problem. After a couple of years they start doing the same thing again. The next time it happens stick the key in the ignition and tap the end of it lightly with a hammer while trying to turn the key. It doesn't always work but some times it might get you away from being stranded.frankjt96 wrote:It's a very common problem, Ford knows about it, but refuses to make a recall on it.
