torque #'s for cam gears and caps?
The bearing caps are tightened in two stages starting with the middle sets and working out. Stage one is 10Nm. Stage two is 19Nm.
I don't know what the torque spec is for the cam gears. I would guess 70ft.lbs. Leave the cam alignment tool in place when tighting the gears but do not rely on it to do all the holding. Use a vice grip as a backing wrench to help hold the cam when torquing the gears.
Paul
