2 things I need help with!
- lox222
- Car: 2006 red ST with the SAP
Ok first is my damn e-brake don't work.how do I adjust them.Then i know a few have or know a few things about the ford contour svt.what I need to know is where can I get new transmission synchros or a new transmission and is the svt one different from other trans,if the other contours cam with a 5 speed.and its a 98
IT'S A FOCUS NOT AN FUCKING EVO!!!!
The e-brake is adjusted with the e-brake handle inside the car, just work it like a ratchet and it'll adjust.
Contact Redlineracer about the trans stuff, he's the SVTC guru here. He'll probably post up on his own though.
- Car: Pitch Black 2007 ZX3 S
Theres all your info on the drive train on a SVTCDrivetrain Differences
The SVT Contour has many high-performance improvements to produce more power and withstand harder driving than the normal Contour models.
These changes include:
* Changes to the camshaft include a longer duration and a complete change in valve timing points.
* Higher compression: 10:to1(SVT) vs 9.7(normal)
* PCM was more aggressively tuned and required premium fuel.
* Larger throttle body (60 mm vs 54 mm). Lifted from the 3.0L Duratec.
* Intake manifold and primary intake ports smoothed by ExtudeHone.
* SVT-Clutch.
* A water to oil, oil cooler to keep control of oil temperatures during performance driving.
* A radiator with a thicker core for better cooling(lifted from Saudi models).
* Different air filter and intake (cone style using same air filter as V6 Mustang).
* A lighter flywheel(from 21lbs to 19lbs.)
* A larger-diameter, quasi-dual exhaust.
These changes allowed the SVT Duratec to make 200hp at 6600rpm and 169lb-ft at 5500rpm. The rev-limiter was also raised to 6750rpm from 6500rpm.
