Help!
jutzb
OK, so I had the silverstars in the stock focus. Now, after paying $180 to replace much of of shorted out headlight wiring I have the stock headlights back in. Ford says the wattage was too high..ok..fine..What do I need to do to have those brighter bulbs in without having wiring issues with the car?
Also...does anybody have a favorite paintless dent removal company. I was going to go with Finishing Touch here in Oakdale but I thought i would ask before going with them (again). Damn cars keep getting in my way!
Thanks in advance!
Kaotik Kreation
I feel your pain, a few months ago I too had to fork over 200.00 for a silly mistake. I was told by serveral guys in the mnfoc that to wire high wattage bulbs there needs to be a relay wired in between. I believe if you look through the Tuning\Performace area and find the "Headlight Problem" topic that I started there is the informaiton there you are probably looking for. I would paste it here if I had any clue how to do that.
Car: 2007 Ford Fusion SEL AWD
jutzb wrote: OK, so I had the silverstars in the stock focus. Now, after paying $180 to replace much of of shorted out headlight wiring I have the stock headlights back in. Ford says the wattage was too high..ok..fine..What do I need to do to have those brighter bulbs in without having wiring issues with the car?
Thanks in advance!
you will have to wire in automotive relays, you can get relay kits for our H4 headlights from jegs or summit for around $40 or you can get an auto motive relay from radio shack and wire up your own kit.
jutzb
Thanks for the help...!
