KW Sport kit is made up of:
KW Suspensions Sport Suspension Kit features high quality springs with matched sport dampers(shocks and struts). Drops your Focus 1.75 inches in the front and 1.5 inches in the back. Remember that your Focus starts out with the rear higher than the front. KW has achieved the optimal damper characteristic curve, spring rate and lowering for your Focus producing the new reference standard in fixed height suspension systems. Through the use of KW's new Twin Tube damper, featuring shortened rebound travel range, and lowered, performance coil springs, enthusiasts achieve their desired lowering without sacrificing the suspension travel requirements of the manufacturer. (picture and description as per KW's web site)
I will also include the upper strut bearings so there will be no need for a spring compressor to remove and install the strut bearings from your OE struts....just slide the old ones out...and install the KW's. I have never had any issues regarding alignment with the system.
The kit sells new for $550...I am selling for $250.... I would do $300 installed for you as well if you do not feel comfy doing the install yourself
