Has ~80k I think and has recently replaced the fuel filter (today). Also tested fuel pressure coming out of the pump and it's 50+ psi so that should be no problem.
So for p0171:
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
Which means about a hundred different things good be wrong
Maybe the EGR is staying open and causing the car to stumble like that at idle. If anyone has had DPFE failures before I wouldn't mind hearing some of the symptoms
From here I guess I'll try and catch it while it's stumbling and disconnect and plug the EGR feed to see if the idle improves. Thanks for reading my super long post
