I should have it back together and ready for break in within a week or so, be ready Nils
Anywho here's a teaser pic:
It is new, Theres no reman shortblock for the 24v 3.0.Pappy wrote:It looks.... new.
Very nice. I can't wait to try my new setup against yours
No need to, those are SVT cams and already a more sporty version of the Duratec cams (puts the peak power close to 7k). And since there are 4 a new set is over $1k for little gains in my opinion.KRYPTO wrote:You should of upgraded the cams and gears?
I would have if the motor was already out. Easy to do.
Well the 3L 24v Taurus Bottom end is the exact same physical size as the Contour's 2.5L. All sensors/exhaust/timing components/motor mounts/valve covers/ timing cover/ basically everything bolts up the same even the Heads. Just one tab for needs to be shaved down for the alternator and the pilot bushing needs to be removed if you're using a used block (they're all autos in the Taurus) but my new one didn't even have oneumdivx wrote:as I am a noob when it comes to CSVT's and their engines and all that. Whats the difference between what your doing with and whats stock?
Probably still looking at around 25 mpg out of it. Maybe slightly more if its all highway and at a decent speed. Its premium only anyhow so I usually don't drive this much. Not when the probe gets 32 highway on 87umdivx wrote:whats more reliable the 2.5l or the 3.0? Also would/could you use the 2.5l heads on the 3.0l block? or are the 3.0l heads better?
Also what kind of mpg do you get out of a setup like that?
Why not the 2.5 block and 3.0 heads? Displacement boy!! It's all about displacement.focinite wrote:so if the 2.5 drops in the focie( share alot of parts with the cont). ive for a long time rolled the thought of a 3L swap into a focus with the mtx, or possibly the trans from the escape. i know the couger,probe,focus,contour and escape all are very close to one another. but why not the 2.5 block and the 3l heads . what are the differance in dimentions between the two heads externaly( for fitment reasones).but heres another, the wind star and tuarus are the same platform, the windstar trans fits a 3.0 ohv and a 3.8, witch also is the same bolt pattern of the ranger trans, so why not a 4.0 contour or a 3.8 super coupe contour?![]()
low displacement works well for Formula 1FORDSVTPARTS wrote:Why not the 2.5 block and 3.0 heads? Displacement boy!! It's all about displacement.focinite wrote:so if the 2.5 drops in the focie( share alot of parts with the cont). ive for a long time rolled the thought of a 3L swap into a focus with the mtx, or possibly the trans from the escape. i know the couger,probe,focus,contour and escape all are very close to one another. but why not the 2.5 block and the 3l heads . what are the differance in dimentions between the two heads externaly( for fitment reasones).but heres another, the wind star and tuarus are the same platform, the windstar trans fits a 3.0 ohv and a 3.8, witch also is the same bolt pattern of the ranger trans, so why not a 4.0 contour or a 3.8 super coupe contour?![]()
Biggers better
