You can contact me Via Email @ slapin23[at]charter[dot]net
1- Rockford Fosgate 700S 2ch amp
2- Boston Acoustics RM9 6x9 Midbass drivers
3- MTX RT202 2ch amp
4- Aura Bass Shakers
5- Toshiba CD player
6- Toshiba 5-disk DVD player
7- Hubcap Wall Clock
I have a Rockford Fosgate amplifier I need to get rid of to offset some of my new system's cost.
model number is 700s. I paid $380+tax a couple years ago for it from Ultimate Electronics (audio king at the time) on clearance. MRSP is about $500
350x2 at 2ohms
175x2 at 4ohms
700x1 bridged at 4ohms
Hasn't been used for at least a year as it's been sitting in a cabinet in my garage. never had a problem with it. I used to use it to power a Boston Pro 12.5lf and also an Infinity Kappa Perfect 12.1D-VQ.
Boston Acoustics RM9 6x9's (midbass drivers only, no tweeters)
I've had these in three of my cars. paid $300 for them.
they wont fit in my new car, so I've got no use for them. they have been sitting in my garage for the last 16months
50W RMS
MTX RT202
great LITTLE amp for running front speakers or a small sub. keep in mind most aftermarket CD-Players only do 13-18watts RMS. I was using it to power two Aura Bass Shakers on the back of my driver's seat for some bass to be felt and not heard. works perfect. MSRP $170. would be PERFECT for powering my bass shakers!
Specifications:
*Power output: 37.5 watts RMS x 2 (4 ohm load), 75 watts RMS x 2 (2 ohm load), 150 watts RMS x 1 (bridged mono, 4 ohm load)
*Frequency response: 20 Hz-20 kHz
*THD: Less than 1%
*Signal to noise ratio: Greater than 100 dB
*Dimensions: 9.75" W x 2.1" H x 7.98" L."
I have 4 bass shakers sitting around. they were for a project I never got around to completing. they have around 10hours of use on them
If you don't know what a bass shaker is... read -> http://www.partsexpress.com/pe/showdetl ... er=299-027
a bass shaker is a transducer that is mounted to a surface such as a couch or the bottom of a car seat. it is hooked up to an amplifier which powers them. they turn low frequency sounds, such as bass effects in movies or in music, into something more tangible... VIBRATION. it's basically a speaker without the cone, instead it moves a weight inside of an enclosure to create it's vibration. it's great for adding an additional level of realism to your movies, games, or music.
25watts RMS 4ohms
Toshiba single CD player. works fine. no remote. that's all I can tell ya. lol.
it was given to me by my mom's friend when she moved.
Model is XR9037
Toshiba 5-disk DVD changer
Model SD-k615
works fine. no remote. It's just sitting around waiting for love.
Hubcap Wall Clock
I was inspire one day and made this because I'm such a pimp.
What will ya give me for it?
