1992 F150 4x4
5 speed
4.9L(300-6)
119k miles
Northland Editon, XLT
8' bed
Color Matched topper, fiberglass, tinted glass, screens, lock
Bed liner
Non-factory reciever hitch, wth plug for round or rectangular style plugs
Bench seat
Tape deck w/ 6 disk, pioneer
Bug shield, bed liner, long rubber floor mat
tinted windows, back window blacked out
Shift on the fly 4x4
Dual gas tanks
Oil recently changed, along with air filter
Power windows/locks/steering
Rear wheel ABS
3.55 gears, open dif(do have a trac-lok w/ rebuild kit that could be used as a bargining chip, also have some 10" woofers in a truck box that could be included for a price)
I Bought the truck back in feb/march of this year, from what the prev owner told me, the clutch was done at 80kmiles, the transfer case was rebuilt, tires where put on about the same time, I think. Brakes work great, strong clutch, starts every time, totally bone stock. I recently did u-joints on the rear, changed trans fluid, coolant looks good, I have a t-stat and gasket here for it(fomoco). This thing is in really good shape for its age.
Bad..
Inside door handle broken on driver's side, some scratches, and rust. I think the passenger side window switch needs to be replaced, it works some times and it doesn't, it may be a loose wire, I don't know, I usually just use the driver's side window, only passengers open it. Steering is a bit loose and steering wheel has some wear on it.
I'd like $2,500 obo(there is wiggle room) for it, KBB says its worth $2800 for good shape, and for a '92 minnesota truck, I think its in good shape.
Call me, name is Scott, number is 320-420-1337. I will be around all day/night call any time, leave a name/number if I do not answer.
