*BLING* throttle body!
Image Image Image
Image Image
You can see the ring by the butterfly and the dark grey/porous areas, I cleaned them all up and then gave it a medium polish. Haven't put it in yet, I am going to get some set screws instead of using the screws with the heads and studs that hang out, I want to make it as smooth as possible.
Comments?
very clean!! is it also ported?
Nice! I forgot this was for the PT for a while
Its opened up a touch no one really makes an aftermarket for the pt, I need to find an old neon tb and make it fit ;)
Damn, I thought that was for a fuel injected lawnmower. That is one cute little throttle body :twisted:
FORDSVTPARTS wrote: Damn, I thought that was for a fuel injected lawnmower. That is one cute little throttle body :twisted:
No kidding lol...
A friend of my dads has a race car called a Unipower GT, it uses the engin/trans from a real Mini cooper only mounted in the rear of the car.
You should see the tiny little disc brakes it uses, The car is so small that I litterally can not fit in it.
