Hey clean and norsell
I need the price for new valve spring seals for the fordracing head? 16 count
Thanks
Aron
Part Number and prices
Prices:
Diff bearings-F7RZ-4221-AC $17.58 ea. requires 2
Speed sensor ring-YS4Z-17285-AA $12.93 ea. requires 1
Valve stem seals-YS4Z-6571-CA $2.03 ea. requires 16
Those are list prices at Superior Ford.
2005 ZX3 SES Winter package and Audiphile package
2000 ZX3 CD Silver. Esslinger UDP, Diablosport Chip, S2 Wheels springs and dampers, SVT front bumper
noresull wrote: Prices:
12.93
thanks noresull
To my knowledge, there is no shim kit as what needs to be done is figure out what shim is neccesary then order that shim.
Now, I would not worry about the shimming of it as with the front wheel drive style diffs, it is not as important to shim the diff as there is no way to adjust gear backlash, only the position of the pinion to the ring gear and a new diff will not be off enough to justify re-shimming it. Now, if You were replacing a case half or both, I would recomend it, but not with just the diff. This is how I did Doughboy's diff and it is working good.
noresull wrote: To my knowledge, there is no shim kit as what needs to be done is figure out what shim is neccesary then order that shim.
here is the kit i got from bat it had a ford part number. I will look it up tonight
http://65.109.103.142/files/fdrive.pdf
Well, if there is a ford part for it that's fine, but like I said, shimming isn't neccesary and if You don't want to pay a dealer to do it for you, then You will have to buy some special tools and precision measuring equipment to figure out what shim You need and then You will have to press the outer race out of the case, replace the shim with the neccesary shim and press in the outer race. After all this is done, You more than likely find out it wasn't neccesay to shim the diff as the difference will prolly be minimal.
