have a problem with the foci..
Go back if you can and have them pull the code.  Do you have a check engine light on?
If you have a check engine light on, pull your battery for about 30 min and drive like normal and see if it comes on.
Here is a chart of all the DTC's...get the code and see what it matches up to.
http://forums.focaljet.com/team-tech/42 ... hlight=dtc
It could be just a sensor that came out or something. Same thing happend on my Contour last night. I just plugged in my Xcal2 and reset the DTC's on it.
Same thing on the Focus last year. A sensor went bad. I think it was a DPFE? Sensor. Ford replaced it for free.
you run lean cus you have to much intake!! for your current fuel table.sc0tty8 wrote:focinite wrote:replace the cat!!! better yet ...get rid of yor catrichie_1 wrote:my car is running lean... what can i do to fix teh dumb problem
I have no cat and I run lean.
 wink wink.....bitchesfocinite wrote:you run lean cus you have to much intake!! for your current fuel table.sc0tty8 wrote:focinite wrote: replace the cat!!! better yet ...get rid of yor cat
Its going to get worse before it gets better. I have a head on the way.
focinite," hay scott whats that ping coming from yer engine?" Scott," Oh nothing its just my pistons trying to get out."........sc0tty8 wrote:focinite wrote:you run lean cus you have to much intake!! for your current fuel table.sc0tty8 wrote:
