Sct ProRacer Managment with VF stg 2 blower
Strubmotorsports
Car: 2003 Ford Focus ZX3 SC
If anyone is working with the SCT software, I am too and we can learn from each other I have a few that are working real good for drag racing with a built in studder so you can just hold it to the floor and it will studder at 4000 rpm till you pass 1 mph
then you get full power until you push in the clutch then the studder kicjs in again so you can shift and never let you foot off the gas keeping maximum air pressure.
Graphite ZX3 VFstage 2 Supercharger intercooled, Crower stage 2 forced ind cams, Crower Valve Springs, 9:1 pistons, Fidanza timing gears, Eagle Rods, Extensive Head porting and machined, 9:1 pistons, Fidanza timing gears, Eagle Rods ect..
saintg2005
can't you do the same thing with an MSD Dis2 ignition controller?
NEXT BIG PROJECT:
