Is this a fairly straightforward job? I've got the gasket from Tousley, is there anything else I need?
My valve cover is a Countour cover, does that make a difference?
Valve cover gasket
Which gasket did you buy?
There were a couple different gaskets used on the Contour and they're different than Focus gaskets.
Pappy had a Contour VC, I don't know what he ran for a gasket though...
Knowing Pappy he used a full caulking tube of white bathtub silicone sealantRedlineracer12 wrote:Pappy had a Contour VC, I don't know what he ran for a gasket though...
Everyone knows black caulking = ghetto, white caulking = pimp.FORDSVTPARTS wrote:Knowing Pappy he used a full caulking tube of white bathtub silicone sealantRedlineracer12 wrote:Pappy had a Contour VC, I don't know what he ran for a gasket though...![]()
I just got a Focus one, I didn't even think about the fact I had a Contour cover. Do you have the Contour gaskets in stock? Are there any other grommets, bolts, nuts, etc., that I will need?
Dean
It's completely straight forward.
You need the valve cover gasket for the contour valve cover you have, not for a focus valve cover as they are different.
It depends what year cover it is. We probably have it though, any way you can bring a sample or the cover or is it your only car?hafftrak wrote: I just got a Focus one, I didn't even think about the fact I had a Contour cover. Do you have the Contour gaskets in stock? Are there any other grommets, bolts, nuts, etc., that I will need?
\hafftrak wrote:Everyone knows black caulking = ghetto, white caulking = pimp.
i think that might be racist... idk and idc really. but i be hear that the tube of black is bigger
Had to stop and think about that... yeah, I'm actually down to one car now.FORDSVTPARTS wrote:It depends what year cover it is. We probably have it though, any way you can bring a sample or the cover or is it your only car?hafftrak wrote: I just got a Focus one, I didn't even think about the fact I had a Contour cover. Do you have the Contour gaskets in stock? Are there any other grommets, bolts, nuts, etc., that I will need?
I'll see if Brian knows what year that valve cover is.
Dean
I've also heard that once you start using black caulking, you don't go back to the white caulking.Monkey-Gein wrote:\hafftrak wrote:Everyone knows black caulking = ghetto, white caulking = pimp.
Dean
And once you start with red RTV, you're perpetually shirtless, drunk and sleeping on a park bench...hafftrak wrote:I've also heard that once you start using black caulking, you don't go back to the white caulking.Monkey-Gein wrote:\hafftrak wrote:Everyone knows black caulking = ghetto, white caulking = pimp.
After some research, it look like the '95-'97 Contour valve covers are the ones that fit. It also looks like since mine is an early 2000 car, the gasket I have will work. I'll have to go out and look when I'm not feeling so lazy.
Dean
