Is that a photo of Turbo Tom?Patalrob wrote:
zx3 almost done
- Car: 2012 Infiniti G37x
Just to let you know, i asked if you had it off, i did tighten it. Cause if you had it off at some point, this would be the problem right from the get-go. The gasket is probably bad if you took it off. Simple question. If you dont wanna answer it, get out of the thread. Simple enough.
- Stilz
- Ask me about Enzyte
- Car: 02 SVTF
Maybe we could PUSH it into a tree.
Wow... Settle down Krypto. It was a generic question, not a question in regards to him or his parts.
Why are you acting so rude toward Patalrob? Did he urk you or something? I don't see how, he is a uber calm guy. If anything YOU'RE the one that should go "crash your car into a tree." Maybe you would tone it down a notch or two...
Geeze... Lots of hostility on the forums recently.
I vote uber bann session.
- Stilz
- Car: 02 SVTF
X2zx3pos wrote:Just to let you know, i asked if you had it off, i did tighten it. Cause if you had it off at some point, this would be the problem right from the get-go. The gasket is probably bad if you took it off. Simple question. If you dont wanna answer it, get out of the thread. Simple enough.
Lets just consider everyone on here warned. No more bullshit bickering between eachother about this. If you don't have some kind of advice or constructive post helping to get the issue fixed, don't post it.
But back on back topic, I'm not familar with the car in question. Is this a SVT or Zetec? What codes is it throwing right now?
There was a comment about the intake being loose, have you checked all over for any leaks on the intake system?
hermitmaster wrote:Codes are in the first post. I believe it's a standard Zetec.
After checking and doing a few things, its still pulling the same codes?
I believe only the lean bank code still exists. The other stuff all depends on the outcome of this code.
PS, thanks guys.
Yep, whoever had it before krypto.
euro body, was boosted i believe.
for some reason it had 4dr ebrake cables in it. gotta fix that.
Actually I think it had SVT brake cables in it, All the drum brake cars use the same cables Sedan, hatch whatever.zx3pos wrote:Yep, whoever had it before krypto.
either way they will not work.
You guys all know more about my car then i do, friggen crazy.
care to shed some light on the whole car in general?
