ok here is the deal my battery light has bedn going on and off for a bit now and now its on all they time for the long story click link (http://forums.focaljet.com/team-tech/51 ... t-off.html) so i looked at the alternator harness like the jetters said and 2 of the 3 wires are pulled out.... i need help fixing this as i have no wire skills im hopeing some one could help me today, i could give yeah some money and order a pizza while we work on it please either post here if you can help ill post a pic of it soon so you can see what happened
or you could try me on AIM=OpOrangeZX3
I NEED HELP FAST!!! FIXED!!!
- Resident parts whore
- Car: 2000 autumn orange zx3
PIC AS PROMISED
- has a blownup bomb
- Car: 2002 Malibu Blue ZX3
ouch, i feel for you, I had a similar problem occur last year. You can get a new pigtail set and replace the stock one with a simple solder job. Unfortunately I don't have time to give you a hand but it should be relatively easy if you've soldered before.
reconstruction.
trahma wrote: ouch, i feel for you, I had a similar problem occur last year. You can get a new pigtail set and replace the stock one with a simple solder job. Unfortunately I don't have time to give you a hand but it should be relatively easy if you've soldered before.
where do i got to get a new pigtale set dealership?
and i have not soldered before...
yeah, I had the same problem when I got my car. The PO had just painted ( ) over the warning light. You just go to the dealership, get a new pigtail, and solder it in. It doesn't take long. If I weren't so far away, I'd help, but...
yeah i think i should be ok the only problem is no dealerships open...so ill have to give steve a call in the morning sometime and go and pick on up
will i need a heat gun for the shrink tube or is a lighter ok like ive seen other people use?
well its fixed, called steve today he had the pigtails i picked em up and my baby is as good as new!!
Sucka612 wrote: Good to hear, did you end up doing it yourself?
sorta i had a friend over but he didnt help much
