Suspension in progress...
Is that nut a Nyloc one (that plastic shit inside)?
I'm not sure to be honest. I try not to cut bolts and usually I can get anything out ... the subframe bolts on my stang I had to use a 6' cheater and our truck, but they came out
Did you try heating the nut and going after the bolt? I mean you're putting new bushings in anyways so get that SOB glowing red if you can.
Maybe a nut buster would work, but hardened nuts aren't the easiest to split,
I haven't tried heating the nuts themselves yet, just the bolts from the bottomside. I'm a little weary if sticking a torch on the topside because of what looks to be fuel lines and other stuff. When I bent the breaker bar I had a 3.5' extension so it was about 4' total. That nut breaker, if it isn't strong enough to break the nut will it damage the threading on the inside?
holy shit, i hope when i do my suspension it ain't this hard.
No, the nut on top is welded to the car.OrbitusXpandeR wrote:The inside bolt on the lca's, can I grind the bolt head down and push them out the top?
You seem to be having a lot more trouble than is usual. What kind of impact gun do you have and what air pressure are you running?
I've got an old Ingersol 231 1/2 impact and I've yet to find a nut or bolt it couldn't remove (or break).
- Stilz
- Ask me about Enzyte
- Car: 02 SVTF
I have 2 different 1/2" impacts and I had to cut one of my rear bolts out, so it not a "your not doing it right" situation. Its just being a bioch from the sounds of it.FORDSVTPARTS wrote:No, the nut on top is welded to the car.OrbitusXpandeR wrote:The inside bolt on the lca's, can I grind the bolt head down and push them out the top?
Where are you located Orbitus?
I'm in robbinsdale, right off 100 about 5 miles north of 394. using an electric impact wrench but i'm thinking i'll rent an air wrench when i pick up my lca's from o'reillys. i really hope that top nut wasn't welded in cause it's spinning when turn the bottom bolt now, lol. at this point i don't even care about the sway/stress bars, i just want to get the arms/struts back in so that i can actually bring my car on saturday
- Stilz
- Car: 02 SVTF
I could swing over tomorrow, if you still havn't got it all done.OrbitusXpandeR wrote:I'm in robbinsdale, right off 100 about 5 miles north of 394. using an electric impact wrench but i'm thinking i'll rent an air wrench when i pick up my lca's from o'reillys. i really hope that top nut wasn't welded in cause it's spinning when turn the bottom bolt now, lol. at this point i don't even care about the sway/stress bars, i just want to get the arms/struts back in so that i can actually bring my car on saturday
I'm trying to remember if it was a captive nut or not, I helped patalrob put his subframe and stuff back together but for the life of me I don't recall.OrbitusXpandeR wrote:I'm in robbinsdale, right off 100 about 5 miles north of 394. using an electric impact wrench but i'm thinking i'll rent an air wrench when i pick up my lca's from o'reillys. i really hope that top nut wasn't welded in cause it's spinning when turn the bottom bolt now, lol. at this point i don't even care about the sway/stress bars, i just want to get the arms/struts back in so that i can actually bring my car on saturday
Yeah but what brand guns are they?Stilz wrote:I have 2 different 1/2" impacts and I had to cut one of my rear bolts out, so it not a "your not doing it right" situation. Its just being a bioch from the sounds of it.
Impact guns are NOT all created equal, my dad couldn't believe the power my 231 has compared to his generic 1/2 inch impact.
- Stilz
- Car: 02 SVTF
A 1911 and a peacemaker... I dont know! It just know that they work.FORDSVTPARTS wrote:Yeah but what brand guns are they?Stilz wrote:I have 2 different 1/2" impacts and I had to cut one of my rear bolts out, so it not a "your not doing it right" situation. Its just being a bioch from the sounds of it.
- Stilz
- Car: 02 SVTF
Yea just let me know. I can swing by in the afternoon. Make sure you spray the $#!t out of them and let them sit for a half hour and then spray again.OrbitusXpandeR wrote:if it comes to that i would be beyond grateful. i'll let you know tonight. i just have to pick up an air wrench and a new breaker bar and hope to god i see some movement todayStilz wrote:I could swing over tomorrow, if you still havn't got it all done.
If you buy a cheap impact you're wasting your money, don't forget that.OrbitusXpandeR wrote:if it comes to that i would be beyond grateful. i'll let you know tonight. i just have to pick up an air wrench and a new breaker bar and hope to god i see some movement todayStilz wrote:I could swing over tomorrow, if you still havn't got it all done.
http://www.ingersollrandproducts.com/IS ... m_en-33374
http://www.ingersollrandproducts.com/IS ... m_en=33374
I bought mine used off a Snap-on truck when I worked in the shop and I've owned it for 20 years, these things are bulletproof and powerful!!
http://www.automotivetoolsonline.com/In ... -12-2.html
http://www.northerntool.com/shop/tools/ ... 7802_17802
