sc0tty8 wrote:
Its not rare if someone can call up FS and say "I want what he has" and get it.
There is no DIY in your setup.
All the work is being done by someone else.
Gull wing doors and paint does not make anything rare either.
If you made it awd and 5 speed, that is something that someone could not easily pull off, and, you will get a 3x multiplier when you play nfsu and get on the cover of a mag.
gull wing doors would make it rare, lambo doors wouldn't though
Go for 5 speed and just go with 2-3-4 gears, drop the final gear down to the duratec gear. Turbos like numerically lower gear ratios. Helps them build bost.
sc0tty8 wrote:Go for 5 speed and just go with 2-3-4 gears, drop the final gear down to the duratec gear. Turbos like numerically lower gear ratios. Helps them build bost.
I have the ball rolling on the turbo upgrade, Just waiting on more info from Randy @ FocusSport., Time to look for a winter beater, looks like Eleanor will be gone for a little while I thought about a new ride for a couple hours after the dyno themn made my Decision.
