bflesher's build
Update while waiting for Iminhell, 4 hours into it, rear sway bar is off and ready for new energy suspension greaseable links/end links, 1 rear shock off, 1 broken lca bolt needing to be ground off at the nut and 1 finger tip possibly broken awaiting the ride to the clinic to find out for sure. so far been a great day.
Finger tip bone broken and nail pushed through top of finger, rear suspension removed and ready for new. Right thumb smashed today. What the f@@k was Ford thinking on these bolts/nuts? Had to cut every bolt except for the sway bars. And another 2 hours or so cutting, chiseling, hammering, prying the rear shock nuts of the knuckle and had to cut the shock bolt on one side also as it was completely seized in the bushing. So at this point waiting till tuesday for John, not sure if I have anymore fingers I want to offer up to the car god's for now.
Don't blame Ford, Blame Minnesota.
Stuck suspension hardware is par for the course on almost any car that lives through a few of our winters.
Yes and no. I have used a 4' breaker on bolts before to break them loose but with this car the bolts just snap and half the time they come out you can't reuse it because the threads are jacked. I'd shake my fist but my fingers hurt to much if I shake my fist.
Breaking off bolts is good. Then the get replaced with new ones that you can put grease or anti seize on the treads so next time it's much easier.
Paul
Huge thanks to iminhell for the help, my fingers love you!
RS springs with Eibach pro dampers ride great, firmer then the SVT but not harsh. SVT front brakes added, already had the rears, a little better but no pedal feel since I now lost the stainless brake lines up front but so far like it. Ride height pretty much seems unchanged to the eye but maybe it will settle. Found out rear camber is off so I need to get the bolts and add those and maybe I'll at least line the rear spring bottom coil because now has a clunk. I'll post pics later.
Saga continues. On the way home alignment shop caliper came loose shearing off bolts binding on rotor rotating it down tearing off hose and then punching thorough wheel. Awaiting parts and new wheel(wonder when the rota's will show) but installed the rear camber bolts at least. Luckily this happened only about 1 1/4 miles from the house so the tow wasn't to bad and the speed was low. Also I think that damn squeak is the upper rear control arm to frame bushing so going to soak the shit out of that hoping. Sometimes I wish I drank lol.
