Check Engine Light... Help!
hermitmaster
Car: 2012 Infiniti G37x
Light went off. I don't know if the code is stored or not though. Steve, if you don't mind bringing your Predator to work tomorrow (assuming you read this before then) I will stop by around 1:30 or 2:00 and pull the codes.
dartfork
hermitmaster wrote:Light went off. I don't know if the code is stored or not though. Steve, if you don't mind bringing your Predator to work tomorrow (assuming you read this before then) I will stop by around 1:30 or 2:00 and pull the codes.
Since the light went off, I'm betting this is a gas filler cap code (P0457). Anyone else? Place a wager.
hermitmaster
Interesting theory, although I haven't put gas in my car in over a week. I guess we'll see.
MNiceGuy
Car: 2005 Pitch Black ZX5
If it's like my car, I have a separate check fuel cap light.
Shouldn't be a problem, assuming I can remember it that is. :shock:
hermitmaster
Upstream O2 sensor and alternator load (bad pigtail replaced). I need an O2 sensor. :(
