4 hours!!!! ha, see thats how us mechanics make our money!!! the cam lock is a very special tool that is incredibly sophisticated......im lying, its a peice of steel thats about 1/8 inch thick and about 6inches long, it fits in off set grooves in the back of the cams, it fits in one way and sits flush aginst the upper deck of the head. with out it its like a 1hour job , but no sure bet its spot on.KRYPTO wrote:book said 4 hour job, whats a cam lock?focinite wrote:if you have the cam lock the timing belt is a 45 minute job. walk in the park
timming and belt
wink wink.....bitchesOh it's on!!!focinite wrote:wanna race? ill handy cap myself by using only hand tools.rsheak02 wrote:1 hour tops!!!!!
2003 SVT POWERWORKS (+ other goodies)
The bolt actually isn't on there that hard.... it only specs 85ft lbs of torque....the problem is keeping it from spining when your trying to take if offKRYPTO wrote:hammer and a torchmaybe a 10ft pry bar also
I believe I have a cam gear tool. Pretty simple looking if you ask me. Are you going to be at the Home Deapot meet tomarrow night Krypto? You can use it if needed.
thats where the good old pop shocker comes in. with ninja like skill you can use the palm to strike the ratchet.....also a trick is to use the serp belt as a strap wrench.rsheak02 wrote:The bolt actually isn't on there that hard.... it only specs 85ft lbs of torque....the problem is keeping it from spining when your trying to take if offKRYPTO wrote:hammer and a torchmaybe a 10ft pry bar also
wink wink.....bitchesThank you Sensei'...focinite wrote:thats where the good old pop shocker comes in. with ninja like skill you can use the palm to strike the ratchet.....also a trick is to use the serp belt as a strap wrench.rsheak02 wrote:The bolt actually isn't on there that hard.... it only specs 85ft lbs of torque....the problem is keeping it from spining when your trying to take if offKRYPTO wrote:hammer and a torchmaybe a 10ft pry bar also
Hey, what Home depot meet????!!!!!!!!
- ch435
- Boom. Oh shit...
- Car: 02 Subaru Outback
Depends on weather lol, but tonight should be good. And we are secretly trying to turn this mnsc meet into a focus meet. We already have four foci on a regular basis, the more the merrier!
Let's go boating.
