Driving to dealership...
WASaZX3pos
Car: 01 Canary Yellow zzzZX3
And car felt like it dropped a cyl or two. Very weak then quit. Wouldnt even turn over. Ignition fuse I think went bad, was the forth one from the driver side, of the big ones. Put in a new one, turns over but does not fire at all. Even after cooldown nothing. Anyway, before monday comes around, and they charge me an arm and a leg to diagnose it, was wondering if anyone had any ideas? Thanks in advance.
FocusMech.73155
Car: '07 Focus ST (supertight)
any dummy lights come on before it started to stumble? CEL or battery light?
WASaZX3pos
Nope, no lights or anything!
bflesher
Coils wires maybe, check the pigtail. Check other connections/wires you can see also maybe.
WASaZX3pos
Yes, either fuel or spark related, unless timing belt went, but looked tight still. Just did it maybe 10k ago.
Anyone else?
FocusMech.73155
not fuel......had to be electrical if it would barely turn over
WASaZX3pos
I replaced the fuse. Turns over fine now.
WASaZX3pos
If the serp belt fell off, that would allow nearly no air into the engine, right?
WASaZX3pos wrote:If the serp belt fell off, that would allow nearly no air into the engine, right?
Wrong.
Have you pulled a plug to check for spark?
FocusMech.73155
Timing belt yes, serpentine belt no
WASaZX3pos
Wrong.
Nope, tomorrow night I'll do it. Hopefully something easy. Dealership wouldnt touch it cause all my "aftermarket" stuff. Lol exhaust and a SC, under the hood anyway.
Lost power and then blew the ignition fuse? Sounds like a shorted coil. WCS possible pcm. What engine? I had a wire pull out of my coil harness once...took about four hours to figure that one out. :lol: check your bases....air fuel spark compression then go from there 8)
WASaZX3pos
Did my wires melt? What is that yellow stuff? hmm
Whats going on here?
Oh coil wires, why art thou touching egr tube?
Anyone see what happened after the wire grounded out?
At least its an easy, quick fix, with a trip to Upull.
Then back to the dealer!
WASaZX3pos
focinite wrote:Lost power and then blew the ignition fuse? Sounds like a shorted coil. WCS possible pcm. What engine? I had a wire pull out of my coil harness once...took about four hours to figure that one out. :lol: check your bases....air fuel spark compression then go from there 8)
Genius.
and so it lives.
I was gonna ask what that tube is. :lol:
Glad you found the problem.
